This page features information regarding the beta firmware for the LZW30 that was released on 04/16/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
Fixed the issue when more than one device is associated and the switch is in S0 mode, the second device does not get commands.
Fixed the bulb would occasionally blink once to OFF when re-powered if connected to a traditional switch.
Fixed the parameter 7 value not being able to be set to 10 during local config mode.
Fixed when the switch is ON and associated bulb is OFF, pressing the Aux switch UP would not turn on the associated bulb.
Fixed when local protection is enabled, the settings for "State after power restored" did not work.
Fixed switch responding to Basic Set with Switch Binary Report. It now responds with a Basic Report when a Basic Set is sent and a Switch Binary Report when a Switch Binary Set is sent.
Removed teh CENTRAL_SCENE command class in NIF. This was causing the feature to show up in some systems such as Homeseer even though it is not in the device.
