Firmware Change-log: LZW42 | RBGW Bulb
Latest Production Version = 2.29
Latest Beta Version = 2.31
Summary
Please see below for the change-log for the firmware of the RGBW Multi-Color Bulb (LZW42). This page will be continuously updated with the most up-to-date firmware file locations, bug fixes and enhancements.
The attached .hex file is the Z-Wave Chip Upgrade that is target 0 in the Z-Wave PC Controller software.
Firmware Versions & Links
Please see below for the various versions of the firmware. Please keep in mind there are two parts to this firmware: .otz (Target 0) - Z-Wave MCU and .bin (Target 1) - Holtek MCU.
Links
Click on the below to download the firmware files -- if you have Hubitat, you can right click (Copy link Address) on the hyperlinks to copy the URL for the Firmware Updater
Beta
Production
Coming soon
V2.31 - 02/25/2021
Quickly turn the bulb on / off 3 times to put the bulb into NON-SECURE inclusion mode.
V2.30 - 06/10/2020
Fixed: Removing Color Reports from unsolicited reporting of group 1 to reduce network traffic.
Please see the following KB articles for instructions to update your firmware.
- Generic Hub: https://support.inovelli.com/portal/en/kb/articles/how-to-s-general-how-to-update-firmware-z-stick-z-wave-pc-controller
- SmartThings Secondary Controller: https://support.inovelli.com/portal/en/kb/articles/how-to-update-device-firmware-z-wave-smartthings-secondary-controller-method
- Hubitat Z-Wave Updater: https://support.inovelli.com/portal/en/kb/articles/how-to-update-your-dimmer-switch-firmware-hubitat
Firmware Change-log: LZW31 - Dimmer Switch (Black Series)
Firmware Change-log: LZW31-SN - Dimmer Switch (Red Series)
Latest Production Version = 1.57.otz and 1.45.bin Latest Beta Version = 1.61.otz and 1.45.bin Summary Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the ...
Firmware Change-log: LZW30-SN - On/Off Switch (Red Series)
Latest Production Version = 1.20.otz Latest Beta Version = 1.22.otz Summary Please see below for the change-log for the firmware of the Red On/Off Switch (LZW30-SN). This page will be continuously updated with the most up-to-date firmware file ...
Firmware Change-log: LZW30 - On/Off Switch (Black Series)
Latest Production Version = 1.20.otz Latest Beta Version = 1.22.otz Summary Please see below for the change-log for the firmware of the Red On/Off Switch (LZW30). This page will be continuously updated with the most up-to-date firmware file ...
How To: Update Device Firmware (Z-Wave)
This article is intended for users that are using a separate "Z-Stick" (Z-Wave Controller) than what they have installed in their "hub". This is sometimes necessary if your hub doesn't directly support Z-Wave OTA. For example, SmartThings. There are ...
