Firmware Change-log: LZW31-SN - Dimmer Switch (Red Series)
Latest Production Version = 1.57.otz and 1.45.bin
Latest Beta Version = 1.61.otz and 1.45.bin
Summary
Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the most up-to-date firmware file locations, bug fixes and enhancements.
Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so.
Firmware Versions & Links
Please see below for the various versions of the firmware. Please keep in mind there are two parts to this firmware: .otz (Target 0) - Z-Wave MCU and .bin (Target 1) - Holtek MCU.
Click on the below to download the firmware files -- if you have Hubitat, you can right click (Copy link Address) on the hyperlinks to copy the URL for the Firmware Updater
Beta
Although this is a beta firmware, it is considered stable and has been in use for many months.
Production
V1.61 - 10/19/2021
Fixed - Dimmer sending duplicate reports in certain scenarios while being controlled by certain hubs.
V1.57 - 06/29/2021
Fixed - Optimization of Aux mode in neutral setting.
Fixed - The inoperative issue after changing parameter 8 from high value to low value.
V1.56 - 05/10/2021
Fixed - Further optimization of Aux switch support in neutral and non-neutral.
V1.55 - 04/28/2021
Fixed - When parameter 52 is set to 1 the physical button press would not turn the load off
V1.54 - 04/26/2021
Modify parameter 52 to provide 3 modes. 0 - Normal, 1 - On / Off only mode, 2 - Smart Bulb Mode
Fixed - Aux Can Turn Off but Not On when in Non Neutral mode
Fixed - Protection Set v1 Enabling Protection v2 Remote
Fixed - Boot Loop Issue in Non-Neutral (Red, Green, Blue LED)
Fixed - Aux Switch Not Causing Scenes to be Sent
V1.53 - 03/10/2021
1.53 has been removed temporarily as it is missing some features that were not supposed to be removed. Version 1.54 will be released in its place.
V1.52 - 01/22/2021
Modified Smart Bulb Mode so that the output can only be turned off by sending a BasicSet(0x00).
Fixed: Solve the problem that the power measured by the light is 5W when the load is not connected (caused by inaccurate power measurement at extremely low power consumption).
V1.51 - 01/08/2021
Fixed: Low brightness would brighten and then darken when being dimmed.
Fixed: Issue where the same value of parameter 5 (Minimum Level) appears inconsistently when both parameters 21 (Power Type =1 - Neutral) and 22 (Switch Type = 1 – 3-Way) are set to 1.
V1.49 - 12/16/2020
Remove local configuration mode (to make space for extra features).
Adding parameter 50 to adjust the delay when parameter 51 is set to 1. 1=100ms, 2=200ms, 3=300ms, etc.
2x taps on the config button will now send a configuration report of a value 0 to indicate the animation has stopped.
Have device send “SwitchMultiLevelSet” every 1 second to associated devices as the device dims up & down for association group 3.
Config Button 2x press will turn off a notification and also send a 2x pressed scene to the hub.
V1.48 - 09/01/2020
Fixed: S2 bootstrapping issue. Improves S2 compatibility with 700 series hubs like Hubitat C-7.
V1.47 - 07/17/2020
Fixed: Bug that when you select the parameter in local config mode and do not edit it. If you long press the config key to save it, it will set to 0.
Fixed: If you are OTA during dimming, that will cause the bulb to flash.
Fixed: multiple switches blink green (like they were excluded)when more than one switch is not on a z-ware network and one of those switches is
Add parameter 51, to enable instant on (ie: disable the 700ms delay). Note, if you disable the delay, it will also disable scene control except for Button 1 (ie: tap up 1x or tap down 1x) and button 7 (config button). All other buttons (2-6) will be disabled.
Added parameter 52. Use to put the switch into "smart bulb" mode. If it set to 1, the power will output maximum % when the dimmer is on. 0 = normal operation, 1 = smart bulb.
V1.45 - 06/22/2020
Removed parameter 7 (Invert Switch) and parameter 10 (Default Level) in local configuration mode. This was to make room on the limited Z-wave 500 chip for the following changes:
Increase the output ratio value on the PWM for better compatibility of Smart Bulbs when in single pole or aux switch mode.
Added the ability to change the LED bar to white when parameter 13 is set to 255.
V1.44 - 05/27/2020
Fixed: Bug when double press the switch immediately after using up/down button causes the LED bar to be incorrect.
Fixed: Holtek firmware was saving data too often causing the bulb to flicker.
V1.43 - 04/11/2020
Fixed: Bug that meter report is sent during dimming resulting in an inaccurate report.
Fixed: Bug that power meter value is 0 when light brightness is 0.
Change the calculation method of parameter 20. Change it from % to KWH. 0=0.01KWH, 10=0.1KWH, 100=1KWH; Modify the range value of parameter 20 to 0~127.
Restart the "Safe guard" time of meter report when the level has been changed. The "Safe guard" timer is to prevent network flooding when device power fluctuates.
V1.41 - 03/28/2020
Fixed Energy & power reporting not being disabled when configuration options are set to 0.
Fixed Power reports flooding network when bulb power consumption fluctuates frequently.
Fixed an issue where the interval time of Central Scene notification is far from the expected value.
Fixed the issue of sending two Meter reports when the device is powered on.
Notifications no longer turning off when user adjusts the level or performs various other actions on the switch.
Change the range of parameter 19 to 0,30-32767 to prevent users from choosing a value that may flood the network.
Please see the following KB articles for instructions to update your firmware.
    • Firmware Change-log: LZW31 - Dimmer Switch (Black Series)
    • Firmware Change-log: LZW30-SN - On/Off Switch (Red Series)
      Latest Production Version = 1.20.otz Latest Beta Version = 1.22.otz Summary Please see below for the change-log for the firmware of the Red On/Off Switch (LZW30-SN). This page will be continuously updated with the most up-to-date firmware file ...
    • How To: Update your Dimmer Switch Firmware | Hubitat
      Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so. Updating the firmware is a fairly safe & fool proof procedure ...
    • Firmware v1.45 (Beta) | LZW31-SN | Dimmer - Red Series (Gen 2)
      Update: Firmware 1.45 has been replaced with 1.47 that has more bug fixes and enhancements. Info can be found here: https://support.inovelli.com/portal/en/kb/articles/firmware-v1-47-beta-lzw31-sn-dimmer-red-series-gen-2 This page features information ...
