Firmware Change-log: LZW30-SN - On/Off Switch (Red Series)
Latest Production Version = 1.20.otz
Latest Beta Version = 1.22.otz
Summary
Please see below for the change-log for the firmware of the Red On/Off Switch (LZW30-SN). This page will be continuously updated with the most up-to-date firmware file locations, bug fixes and enhancements.
Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so.
Firmware Versions & Links
Please see below for the various versions of the firmware. Please keep in mind there is one part to this firmware: .otz (Target 0) - Z-Wave MCU.
Click on the below to download the firmware files -- if you have Hubitat, you can right click (Copy link Address) on the hyperlinks to copy the URL for the Firmware Updater
Beta
Production
V1.22 - 05/10/2021
Fixed the bug that the V1 version of Protection Set Command would cause RF state of Protection to become enabled. This mostly affected Home Assistant users as it is still using V1 of this command class.
V1.21 - 08/17/2020
S2 inclusion optimization for 700 series hubs.
V1.20 - 07/14/2020
Change that optimizes Z-Wave exclusion during mass production. Intended for quality testing after assembly.
V1.19 - 07/06/2020
Add parameter 51, to enable instant on (ie: disable the 700ms delay). Note, if you disable the delay, it will also disable scene control except for Button 1 (ie: tap up 1x or tap down 1x) and button 7 (config button). All other buttons (2-6) will be disabled.
Added the LED color, "White" when parameter 5 is set to 255.
V1.17 - 05/01/2020
Fixed: multiple switches blink green(like they were excluded)when more than one switch is not on a z-ware network and one of those switches is
excluded.
Fixed: when the load is off, setting parameter 3(auto off time) problem. Sometimes the timer would be incorrect the first time the load turned off.
Fixed: when the parameter 3 is set from non-zero to zero, it is immediately closed if the load is on.
Add parameter 13, for some special load types. Can be used in certain 3-way dumb switch setups where the load is confusing the switch as to which state it should be in.
Parameter 13
Default: 0
0: Detect Load Type.
1: Manually set for special load type.
V1.16 - 04/16/2020
Fixed Energy & power reporting not being disabled when configuration options are set to 0.
Fixed Power reports flooding network when bulb power consumption fluctuates frequently.
Fixed the issue of sending two Meter reports when the device is powered on.
Fixed the issue when more than one device is associated and the switch is in S0 mode, the second device does not get commands.
Fixed the bulb would occasionally blink once to OFF when re-powered if connected to a traditional switch.
Fixed the parameter 7 value not being able to be set to 10 during local config mode.
Fixed when the switch is ON and associated bulb is OFF, pressing the Aux switch UP would not turn on the associated bulb.
Fixed when local protection is enabled, the settings for "State after power restored" did not work.
Fixed switch responding to Basic Set with Switch Binary Report. It now responds with a Basic Report when a Basic Set is sent and a Switch Binary Report when a Switch Binary Set is sent.
Change the range of parameter 11 to 0,30-32767 to prevent users from choosing a value that may flood the network.
Switch will send an energy report when first included into the network.
Since there is a "protection" that prevents the switch from sending multiple power reports (flooding) when the power is fluctuating frequently, the switch will now send a power report immediately when turned on/off and the "protection" timer will be reset.
      Latest Production Version = 1.57.otz and 1.45.bin Latest Beta Version = 1.61.otz and 1.45.bin Summary Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the ...
    • Firmware Change-log: LZW31 - Dimmer Switch (Black Series)
    • How To: Update your Dimmer Switch Firmware | Hubitat
      Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so. Updating the firmware is a fairly safe & fool proof procedure ...
