Firmware v1.41 (Beta) | LZW31-SN | Dimmer - Red Series (Gen 2)
Update: Firmware 1.41 has been replaced with 1.43 that has more bug fixes and enhancements. Info can be found here:
This page features information regarding the beta firmware for the LZW31-SN that was released on 03/27/2020. This firmware is intended for users that would like to test the fixes and features included in this release before it goes into production. It should be a fairly stable release that fixes several issues.
The Holtek .bin file is the LED bar MCU firmware and is target 1 in the Z-Wave PC Controller software.
Please proceed at your own risk. Bricked switches due to user error will not be replaced nor refunded. If you'd like to mail in your switch to have us do it for you, we're happy to do so.
Fixed Energy & power reporting not being disabled when configuration options are set to 0.
Fixed Power reports flooding network when bulb power consumption fluctuates frequently.
Fixed an issue where the interval time of Central Scene notification is far from the expected value.
Fixed the issue of sending two Meter reports when the device is powered on.
Notifications no longer turning off when user adjusts the level or performs various other actions on the switch.
Change the range of parameter 19 to 0,30-32767 to prevent users from choosing a value that may flood the network.
      Latest Production Version = 1.57.otz and 1.45.bin Latest Beta Version = 1.61.otz and 1.45.bin Summary Please see below for the change-log for the firmware of the Red Series Dimmer Switch (LZW31-SN). This page will be continuously updated with the ...
    • Inclusion / Exclusion | Dimmer - Red Series (Gen 2)
      Summary (TLDR) Please see below for basic inclusion/exclusion information around the LZW31-SN - Red Series Dimmer Switch. For more hub/gateway specialized instructions, please click on the URL's in the third section below to be taken to the specific ...
