FAQ's: Button Mapping for Scene Control
Below you'll find the various button mappings for our products. These mappings will help you setup your scenes (ie: 2x Tap, 3x Tap, etc) from within your hub.
The following products have scene control built in:
  1. VZM31-SN - Blue Series 2-1 Switch (On/Off & Dimmer)
  2. LZW30-SN - Red Series On/Off Switch
  3. LZW31-SN - Red Series Dimmer Switch
  4. LZW36 - Red Series Fan/Light Switch
  5. LZW45 - Red Series Lightstrip & Controller Kit
  6. NZW30-S - Gen 1 On/Off Switch w/Scenes
  7. NZW31-S - Gen 2 Dimmer Switch w/Scenes
How to Interpret the Button Mapping Charts
Below you'll see a series of charts that will let you know how to program your switch via the hub using buttons. An example would be if you wanted to double tap up on your light switch to activate a scene. Using this example, you can go to figure 1.1 - Red Series On/Off Switch Button Mapping Chart and you'll see that, "Button 2" = Double Tap. Since you want to use the top of the paddle to activate this scene, you would then select, "Pushed" (whereas if you wanted to use the bottom of the paddle, you would select, "Held").
All hubs that support scene control will use the verbiage from within the charts (ie: Button #, Pushed or Held).
Please see below for product button mapping.
Action
Button #
Event
Tap Up on Light Paddle 1x
1
Pushed
Tap Up on Light Paddle 2x
2
Pushed
Tap Up on Light Paddle 3x
3
Pushed
Tap Up on Light Paddle 4x
4
Pushed
Tap Up on Light Paddle 5x
5
Pushed
Hold Up on Light Paddle
8
Pushed
Release Up on Light Paddle
6
Pushed
Tap Down on Light Paddle 1x
1
Held
Tap Down on Light Paddle 2x
2
Held
Tap Down on Light Paddle 3x
3
Held
Tap Down on Light Paddle 4x
4
Held
Tap Down on Light Paddle 5x
5
Held
Hold Down on Light Paddle
8
Held
Release Down on Light Paddle
6
Held
Tap Config Button 1x
7
Pushed
Action
Button #
Event
1
Pushed
2
Pushed
3
Pushed
4
Pushed
5
Pushed
8Pushed
6Pushed
1
Held
2
Held
3
Held
4
Held
5
Held
8Held
6Held
7
Pushed
Action
Button #
Event
Tap on Light Button 1x
1
Pushed
Tap on Light Button 2x
2
Pushed
Tap on Light Button 3x
3
Pushed
Tap on Light Button 4x
4
Pushed
Tap on Light Button 5x
5
Pushed
Hold on Light Button (3 sec)
8
Pushed
Release on Light (after Hold) Button
6
Pushed
Tap on Light Rocker Up
7
Pushed
Tap on Light Rocker Down
7
Held
Tap on Fan Button 1x
1
Held
Tap on Fan Button 2x
2
Held
Tap on Fan Button 3x
3
Held
Tap on Fan Button 4x
4
Held
Tap on Fan Button 5x
5
Held
Hold on Fan Button (3 sec)
8Held
Release on Fan (after Hold) Button
6Held
Tap on Fan Rocker Up
9Pushed
Tap on Fan Rocker Down
9
Held
Action
Button #
Event
Release the Up Arrow (After 3 Seconds)
0
Pushed
Tap Up on Up Arrow 1x
1
Pushed
Tap Up on Up Arrow 2x
2
Pushed
Tap Up on Up Arrow 3x
3
Pushed
Tap Up on Up Arrow 4x
4
Pushed
Tap Up on Up Arrow 5x
5
Pushed
Hold Up on Up Arrow (3 Seconds)
6
Pushed
Release the Down Arrow (After 3 Seconds)
0
Held
Tap Down on Down Arrow 1x
1
Held
Tap Down on Down Arrow 2x
2
Held
Tap Down on Down Arrow 3x
3
Held
Tap Down on Down Arrow 4x
4
Held
Tap Down on Down Arrow 5x
5
Held
Hold Down on Down Arrow (3 Seconds)
6
Held
Tap Config Button 1x7Pushed
Action
Button #
Event
1
Pushed
2
Pushed
3
Pushed
4
Pushed
5
Pushed
6
Pushed
1
Held
2
Held
3
Held
4
Held
5
Held
6
Held
NZW31-S - Gen 1 Dimmer Switch
Action
Button #
Event
1
Pushed
2
Pushed
3
Pushed
4
Pushed
5
Pushed
6
Pushed
1
Held
2
Held
3
Held
4
Held
5
Held
6
Held
    • How To: Create a Scene From Your Smart Switch | SmartThings
      Summary (TLDR) In this article, we'll show you how to create a scene from your smart switch. What this means is that you can double-tap, triple-tap, etc to create various scenes using other smart home products. An example would be: between the hours ...
    • How To: Create a Scene with RGBW Bulbs | SmartThings
      Overview Our Red Series Switches come with the ability to create scenes directly from the switch. What this means is that you can tap on the switch and trigger a lighting scene such as turning on your smart bulbs to purple for movie night or tapping ...
    • How To: Create the Ultimate Bedtime Scene | SmartThings
      Overview In this article, we'll show you how a single button on a switch can prepare your entire house for bedtime. We'll show you how you can have your house lock all doors, turn off all lights, make sure your garage door is closed, and your ...
    • Setting Up Scenes | LZW31-SN | Dimmer - Red Series (Gen 2) | SmartThings
      This article will walk you through how to setup custom scenes using your Inovelli Red Series Dimmer Switch and the LZW31-SN Device Handler. Z-Wave Scenes are useful if you want to control multiple smart devices or trigger routines. For example, you ...
    • Setting Up Scenes | LZW30-SN | On/Off - Red Series (Gen 2) | SmartThings
      This article will walk you through how to setup custom scenes using your Inovelli Red Series On/Off Switch  and the LZW30-SN Device Handler. Z-Wave Scenes are useful if you want to control multiple smart devices or trigger routines. For example, you ...
