Device Driver Installation | LZW45 | Lightstrip & Controller Kit
This article will walk you through how to install the device driver for optimal usage and advanced functionality on your
Inovelli LED Strip & Controller Kit (LZW45). We promise it's not hard and should take you 5-10 minutes tops.
Hubitat Web Interface Open: portal.hubitat.com (once logged in, click on, "Drivers Code")
Device Handler Code Tab Open: LZW45 Raw Code
Installing the Device Driver
We recommend installing the device driver prior to installing your controller for ease of installation.
Installing the Code for the Lightstrip Controller
- Inside the Hubitat web interface, select the “<> Drivers Code” Button on the left side bar
- Then click, “New Driver” (top right)
- Now switch tabs and go to the driver link: LZW45 Device Driver Raw Code
- Select all code and copy it
- Go back to the Hubitat web interface and paste the code into the white box
- Click, “Save” – wait for the red, “Modified” word to disappear (this indicates the code was saved properly)
Device Handler Installation | LZW45 | Lightstrip & Controller Kit
This article will walk you through the features of the custom device handler and how to install it for optimal usage and advanced functionality on your Inovelli LED Strip & Controller Kit (LZW45) . We promise it's not hard and should take you 5-10 ...
Spec Sheet | RGBTW Smart LED Strip & Controller Kit | LZW45
The LZW45 Inovelli RGBTW Smart LED Strip is the first Z-Wave enabled individually addressable lightstrip that works with many different hubs and gateways and allows remote control from anywhere in the world. Overview Make: Inovelli Model #: LZW45 ...
Setting Up Notifications | LZW45 | Lightstrip & Controller Kit | SmartThings
This article will walk you through how to setup custom notifications using your Inovelli Red Series Lightstrip & Controller Kit and the LZW45 Device Handler. Notifications are useful if you want to have a heads up visual of an action. For example, ...
Hubitat Device Drivers
Device Driver Locations Please see the following locations for each Inovelli Device Driver. Then follow the instructions below! Master Location: https://github.com/InovelliUSA/Hubitat Switches LZW30 - On/Off (Black Series) - Gen 2 LZW30-SN - On/Off ...
Setting Up Scenes | LZW45 | Lightstrip & Controller Kit | SmartThings
This article will walk you through how to setup custom scenes using your Inovelli Red Series Lightstrip & Controller Kit and the LZW45 Device Handler. Z-Wave Scenes are useful if you want to control multiple smart devices or trigger routines. For ...
