Compatible Bulbs for Inovelli Dimmer Switches Red and Black Series
Compatible Bulbs - Gen 2 Dimmers
Note: This is a live document that is constantly changing. If you'd like to make a contribution, please post in our community or reach out to us.
There are many different bulbs that are compatible with our dimmer switches. The important thing to remember is that our dimmers use MOSFET, leading edge technology, so the bulb(s) you choose should be the same (ie: MLV, not ELV). Below are bulbs that are compatible and not compatible with our dimmers and the optimal min/max settings that you should program your switch to.
This article relates to our Gen 2 dimmers (Red & Black Series):
Compatible & Non-Compatible Bulbs
Below are the bulbs that have been tested with our Gen 2 Dimmers by either us or the community. Some will require a min/max setting from the switch which is noted in the 4th column (NOTE: Some may still have to be tweaked based on your setup).
Brand
Type (Style, Wattage, Kelvin)
Model
Compatibility, Min/Max Settings
Where to Buy
Notes
Commercial Electric
Style: Flood Light
Wattage: 28W
Kelvin: 3000K (Warm)
SPTM2-2802
Compatible = Notes
Min: 0
Max: 100
Need to set Parameters 1-4 to 0 as this is not a dimmable bulb. Use at own risk.
Commercial Electric
Style: Recessed (6")
Wattage: 11W
Kelvin: 2700K-5000K
53804101
Compatible = Notes
Min: 0
Max: 100
Need to set Parameter 1 to 0 per this thread.
Commercial Electric
Style: Flat Panel (1-4')
Wattage: 80W Equiv.
Kelvin: 4000K (Cool)
74031/HD-G2
Not Compatible
Not Compatible
Cree
Style: A19, E26
Wattage: 40W Equiv.
Kelvin: 2700K (Warm)
SA19-04627MDFD-12DE26-1-14
Compatible = Yes
Min: 15
Max: 100
Cree
Style: A19, E26
Wattage: 60W Equiv.
TA19-08027MDFH25-12DE26-1-12
Compatible = Yes
Min: 15
Max: 100
Cree
Style: BR30, E26
Wattage: 65W Equiv.
Kelvin: Various
TBR30-06527FLFH25-12DE26-1-12
Compatible = Yes
Min: 15
Max: 100
Eaton
Style: Recessed (4")
Wattage: 65W Equiv.
RA5606930WHR
Compatible = Yes
Min: 15
Max: 100
Eaton
Wattage: 65W Equiv.
SMD4S6940WH
Compatible = Yes
Min: 15
Max: 100
Eaton
Wattage: 9.8W
ML5609930
Compatible = Yes
Min: Not Sure
Max: 100
Eaton
Wattage: 65W Equiv.
LT460WH6930R
Compatible = Yes
Min: Not Sure
Max: 100
Eaton
Wattage: 65W Equiv.
RL560WH6940R
Compatible = Yes
Min: Not Sure
Max: 100
Eaton
Wattage: 65W Equiv.
Kelvin: 2700K-5000K
SMD6R6940WH
Compatible = Yes
Min: Not Sure
Max: 100
EcoSmart
Style: A19, E26
Wattage: 60W Equiv.
A810SS-Q1D-01
Compatible = Yes
Min: Not Sure
Max: 100
Feit
Style: A19, E26
Wattage: 60W Equiv.
BPOM60/830/LED
Not Compatible
Not Compatible
Feit
Style: A19, E26
Wattage: 40W Equiv.
OM40DM/927CA/LED
Not Compatible
Not Compatible
Feit
Style: MR16
Wattage: 50-watt
Kelvin: 3600
EXN
Compatible = Yes
Min: Not Sure
Max: Not Sure
FENG@YE
Wattage: 65W Equiv.
AFR4C-0930
Not Compatible
Not Compatible
GE
Style: A19, E26 (CFL)
Wattage: 60W Equiv.
89623
Compatible = Yes
Min: Not Sure
Max: 100
CFL Bulb
GE
Style: A19, E26
Wattage: Varies
Kelvin: Varies
Compatible with all Reveal Line (A19, E26)
Compatible = Yes
Min: 42
Max: 87
Compatible per this thread
GE
Style: A19, E26
Wattage: Varies
Kelvin: Varies
Compatible with all Relax Line (A19, E26)
Compatible = Yes
Min: 42
Max: 87
GE
Style: BR30, E26
Wattage: 65W Equiv.
LED10DR303/827W
Not Compatible
Not Compatible
GE
Style: Candelabra
Wattage: 60W Equiv.
42550 (Lowes), 35550 (Walmart)
Compatible = Yes
Min: Not Sure
Max: 100
GE
Style: Under Cabinet Fixture
Wattage: 16.86W
Kelvin: 3000K-5000W
Enbrighten Line: 12" (SKU: 34285), 18" (SKU: 34287), 24" (SKU: 34289)
Compatible = Yes
Min: Not Sure
Max: 100
Hamilton Hills
Style: Recessed (8")
Wattage: 15W
Kelvin: Varies
Bronze: HH1061-L
Brushed Nickel: HH1048
White: HH1085-L
Compatible = Yes
Min: Not Sure
Max: 100
Amazon link will take you to the bronze variation, but you can choose whichever.
Hyperikon
Style: Recessed (14")
Wattage: 15W
442251031
Not Compatible
Not Compatible
IKEA
Style: A19, E26
Wattage: Not Sure
Not Sure: RYET Line
Not Compatible
Not Compatible
ILAMIQI
Style: E12
Wattage: 10W
Applies to all Variations on Amazon, Amazon.ca
Not Compatible
Not Compatible
Lithonia
Style: Recessed (Varies)
Wattage: Varies
Kelvin: Varies
Applies to all Lithonia Recessed fixture variations listed on the Amazon URL
Not Compatible
Not Compatible
Philips
Style: Candelabra
Wattage: 60W Equiv.
Kelvin: 5000K (Cold)
550300
Not Compatible
Not Compatible
Sea Gull
Wattage: 14W
14701S-15 (Discontinued)
Not Compatible
Not Compatible
Sylvania
Style: BR30, E26
Wattage: 65W Equiv.
73954
Compatible = Yes
Min: Not Sure
Max: 100
Sylvania
Style: Candelabra
Wattage: 25W Equiv.
CF5EL
Not Compatible
Not Compatible
Trans Globe Lighting
Wattage: 13W
LED-30015 ROB
Not Compatible
Not Compatible
WAC Lighting
Style: Recessed (15")
Wattage: Varies
Kelvin: Varies
Applies to all WAC fixtures on the Amazon listing
Compatible = Yes
Min: Not Sure
Max: 100
    • Compatible Bulbs & Fans - Fan/Light Switch
      Note: This is a live document that is constantly changing Summary (TLDR) There are many different bulbs and fans that are compatible with our fan and light switch. The important thing to remember is that our dimming portion of the fan/light switch ...
    • Spec Sheet | Dimmer - Black Series (Gen 2) | LZW31
    • Troubleshooting: Buzzing (Humming) From the Switch or Light
      Summary (TLDR) If there is buzzing coming from the light switch, then ensure the load attached to the switch is under the maximum wattage. If it is, then unfortunately you have a defective switch -- please reach out to us for an RMA. However, if your ...
    • Spec Sheet | Dimmer (Gen 1) | NZW31
      The NZW31 Inovelli Dimmer Switch is a Z-Wave enabled smart switch that works with many different hubs and gateways and allows remote control from anywhere in the world. Overview Make: Inovelli Model #: NZW31 Generation: First (Predecessor To: Second ...
