Button Combination Cheat Sheet | Fan + Light - Red Series (Gen 2) | LZW36
Changing Settings at the Switch | Fan + Light - Red Series (Gen 2) | LZW36
Below is a table of setting you can change by using the corresponding tap commands on the switch.
    • Spec Sheet | Fan + Light - Red Series (Gen 2) | LZW36
      NOTE: This is a work in progress and features/specs are subject to change. Please see our community thread to stay up to date: https://community.inovelli.com/t/fan-light-switch-project-hurricane-pre-orders-now-open/23 The LZW36 Inovelli Fan + Light ...
    • Spec Sheet | Dimmer - Black Series (Gen 2) | LZW31
    • Installation & Setup | LZW36 | Fan + Light Red Series (Gen 2) | SmartThings
